89' Civic Weird Starting Problems
I have an 89 civic hatchback that would start up for a split second and dies. This happens off and on, but its still a problem none-the-less. I dunno if its fuel or a power issue. If anyone can help, id very grateful.
so i was trying to leave work and it was acting up again. i had the e-brake up and tried to start it, after it started and died the e-brake light did go out after it died. How do i get to the ignition switch? and can i get a second opinion from anyone before i change it?
It's a common problem. If you can make the dash lights go off and on by jiggling the key around in position II (normal run position), the switch is definitely bad.
To replace switch, disconnect the battery (good idea for any electrical work), remove the plastic panel below the dash that accesses the fuse box, remove the metal brace behind that plastic panel. Then remove the "clamshell" cover over the steering column (take out the screw at the bottom and metal ring at the wheel end, then snap it apart). It's probably easier to take the steering wheel off first but not essential. Once you have the cover off, unscrew the 2 Philips screws holding the switch to the back of the key cylinder (access is not easy) unplug wires and remove switch.
Brian1997
07-25-2014 05:04 AM
totenkopf
05-31-2007 03:36 PM
