86 civic hatchback has no spark
I have a no spark condition i have tried a new distrubitor because i found a ignitor test online and i have returned 4 dist to 2 different vendors and i cannot determine if i have preformed the right tests .. does anyone know the ignition tests for a 86 civic with a carb and automatic thanks
First, realize that if the timing belt is stripped, distributor won't rotate, and no sparks will fire.
The electrics are real simple. Power from the ignition switch and fuse arrives on the yellow-black wires. Check that the igniter and the coil get power when the key is on, and while cranking. Have you tried changing the coil?
Slammed98silvercoupe
10-29-2010 05:20 PM
her98civicex
06-04-2010 12:48 PM
katies95
12-18-2006 05:07 PM
