6th gen Civic EX ECU
RE: 6th gen Civic EX ECU
Do you know what problem triggered the ECU to default to limp mode? It may be important first to address this problem, if known.
Otherwise, you could try resetting the ECU by removing the 7.5A BACKUP fuse in the under-hood fuse/relay box for 10 seconds and then reinserting it.
Before resetting the ECU, you should retrieve the CEL trouble code(s) as described here:
http://www.c-speedracing.com/faq/06.php
A link at the website above lists the meaning of each CEL code. Post your findings if you would like more feedback.
Why do you think the air filter is causing the problem?
The CEL code in the ECU may reveal a different problem.
By the way, do you think the ECU entered the Fail-Safe or Back-Up function (see picture)?
[IMG]local://upfiles/25538/E2F29AA556184C6BBCC5C69C4CA55C7C.jpg[/IMG]
1. Read codes and write them down. Do not act right away because sometimes codes get set falsely and they are remembered for a long time.
2. Reset the ECU and test drive.
3. If the CEL comes back on or it stays in limp mode, read the codes again and resolve the problem causing the code. The codes you see now that were also present in step 1 are most likely due to real problems.
