2010 civic down hill acceleration
Old 05-14-2011 | 07:37 PM
tslam195's Avatar
Question 2010 civic down hill acceleration
I notice whenever my Civic 2010 is going down hill and the brake is applied, the RPM always goes up to between 3000-4000 and the speedometer shows 40mph. How could this happen?
I thought if I am going up hill and step on the gas peddle, the RPM will always tend to go up.
Any suggestions.
Thanks for your response.
Old 05-16-2011 | 12:10 PM
mundy5's Avatar
that's b/c it is downshifting hence higher rpm; you have an auto transmission right?
Old 05-17-2011 | 08:38 AM
tslam195's Avatar
Wink
You are correct.
So the downshifting causes the RPM to blow through the roof. Is there any ways to avoid this from happening.
I guess this high RPM could be damaging to the engine. Am I correct?
Old 05-17-2011 | 10:20 AM
mundy5's Avatar
well, 3-4k is not a damaging rpm (i.e. it is not blowing through the roof) though I'd say you ought to bring it by the dealer and let them know. it still sounds higher than it should be.
When I shift, I normal shift at 3 k to the next higher gear using a manual trans. If you look at the tachometer, you'll see the red line begin around 5k or 5.5k
Old 05-17-2011 | 10:37 AM
DaOne's Avatar
IMO it sounds like its using engine braking to help slow it down. instead of only using the brakes.
Old 05-18-2011 | 08:34 AM
tslam195's Avatar
Smile High RPM going downhill
I think so. Even if I apply the brake, the RPM seems a bit high. I have a stick shift Accord and the RPM normally will be under 2000 RPM going downhill. I was surprise the Civic automatic uses the engine to slow down the car.
Even 4000 RPM is not at the warning limit but I still consider this to be a little bit odd the car will apply the 'brake' itself even though the brake paddle is applied.
Is this by design? or there is something wrong with the car?
TJSwoboda
02-22-2015 05:55 AM
mcwheels
08-18-2010 10:33 AM
burgernuds
11-06-2008 07:07 AM
gramfam
04-19-2007 10:39 AM
Fiirkan
08-22-2006 03:14 AM
