2008 Honda Civic Cracked Engine Block and now Bad heating core
Old 06-07-2016 | 10:01 AM
rbnz's Avatar
Default 2008 Honda Civic Cracked Engine Block and now Bad heating core
I recently had to have the engine block replaced by Honda due to a crack in the block which was causing me to lose coolant and making the car over heat. Got that fixed along with the engine mounts and not even a week later the car started over heating and I was replacing the coolant multiple times a day. I have coolant leaking (gushing) into the cab of the car on the driver side and passenger side under the dash.
Could they have caused a problem with the heating core when they were replacing the engine block? Or could this be a new issue that just popped up.
Old 06-07-2016 | 11:00 PM
droopy128's Avatar
it a possibly.. check the heater hose that connect into the firewall see if it seated correctly.
slowstepper
12-20-2014 05:37 PM
coxj_sd
07-30-2009 02:31 PM
want4rain
04-23-2008 05:06 AM
dawnbhowell
11-07-2007 07:56 PM
chriskatana
08-10-2005 11:15 AM
