Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
The other gears, including reverse, work OK? If so that would suggest a problem with the shift linkage, or the motor mounts are bad enough that the transmission is way out of alignment with the car.
