2006 LX Stuck Window
Old 02-19-2010 | 07:52 AM
Schwizzle's Avatar
Default 2006 LX Stuck Window
My rear passenger's side window is stuck in the up position. I rarely roll it down, so I have no idea how long it's been stuck. The only thing I'm sure ofis that it's not just a problem with my window switch since neither the driver's nor the rear passenger's buttons work.
I don't know if the tutorial already up on slow moving windows applies since the window doesn't move at all. Also, my Civic is a much newer body style than the one in the pictures i nthe tutorial (2006 LX 4-dr).
Anyone have suggestions? I'm sure I can do the work myself with instructions, but haven't ever really dealt with maintenance on a car before.
Old 02-19-2010 | 12:35 PM
I'd start by taking the door panel off and see if power reaches the motor when the button is pressed. If it does the window is jammed or the motor is bad. If not there is an electrical problem somewhere else. I think that the wires in the driver's door can break and disable both switches but would need a diagram of the 2006 to be sure.
cutlass1970w31
02-25-2020 10:13 PM
jjcard41
12-11-2014 12:11 PM
galaxygreygirl
10-04-2011 12:17 PM
boynblue
10-07-2005 01:02 PM
boynblue
10-05-2005 09:23 AM
Quick Reply: 2006 LX Stuck Window
