2006 A/C Problem
2006 A/C Problem
EX Coupe, 105K miles
Going down the road at 55+ mph, can feel engine drag from A/C clutch, as it engages. Enough where I have heard what sounds like belt slip.
Starting having the issue after I dumped about half a can of 134A into the A/C System.
Car on with the A/C on; at idle, Clutch engages/Condenser Fan engages. Clutch disengages/Condenser Fan disengages. Fan does not stay on full time, only when the clutch engages, is this normal?
Put gauges on the car;
95 degrees F, ambient
Idle 32/180
1500 rpms
Clutch engage - 22/225
Clutch disengage - 40/200
Are the readings with in normal range?
Any advice would be greatly appreciated.
Idle 32/180
1500 rpms
06civic420
12-08-2011 01:19 PM
