2003 LX Air Conditioner Drain Tube
Old 07-18-2006 | 06:12 PM
Kevinminnick's Avatar
Default 2003 LX Air Conditioner Drain Tube
I am having problems with my air conditioner leaking inside my passenger floor. I know I have a plugged drain tube, but I can't seem to locate it anywhere on the car. I've been under the hood, under the car, and have had the passenger side of the dadhboard off. Any help with this would be greatly appreciated. Thank you very much!!!
Old 07-18-2006 | 08:15 PM
Default RE: 2003 LX Air Conditioner Drain Tube
Ok, well, with some searching I found it!! It is definately nothing you want to get at from under the hood. If you jack up the car, you need to go about dead center of the fire wall, and it spouts down right about there. It's about a 6-8" long hose which connects to a a male end coming about 3" above it and about 1" behind it. It comes from the car and makes a 90 degree turn towards the passenger side of the car, then it makes another 90 degree bend towards the ground. Aparently, this is a very common thing to get plugged like it did, and very easy to fix, once you know where to look. Good luck if you run into the same problem.
freshane
08-21-2011 10:21 PM
aeromobile
09-20-2006 03:59 PM
runawaylegalsec
04-19-2006 10:19 AM
tonguetwiztid
06-27-2005 10:08 PM
Honda91
01-17-2005 09:31 PM
