2003 EX A/C problem
Old 07-09-2010 | 08:05 PM
Pitik's Avatar
Default 2003 EX A/C problem
Hi Guys I am new here. I was hoping someone can help me out.
My AC had not been working and I got it diagnosed at the Honda Service Center, they told me the thermal protector is faulty. I bought a new one from them and replaced it today but the AC is still not working (((
It looks like everything is connected properly, and I reset the ECU ( i don't know why lol) i am new to this.
I would appreciate your help, its 100 degrees outside.
Old 07-09-2010 | 08:13 PM
A bad thermal protector would prevent the compressor clutch from engaging but not the condenser fan from running. Does the fan fail to run? Does the compressor clutch fail to engage? Do both not work? Does the A/C button illuminate when pushed?
Old 07-09-2010 | 08:24 PM
Is the protector wired direct to the clutch, or does it have its own small wires?
Either way the first step in troubleshooting is to note whether or not the fans under the hood start when you press the button.
Old 07-10-2010 | 05:51 AM
Pitik's Avatar
Hi guys,thanks for the replies.
The condenser fan is not running, and it feels like the clutch is not engaging either, the AC light does come on when pushed.
The Thermal protector has wires of its own one of which is a ground wire directly connected to the bolt, the other is a red wire connecting to the clutch, both of which i reconnected when replacing the old TPS.
I also recharged the system this morning, the pressure is ok.
Any ideas what's the next step? What puzzles me is that the dealer service diagnosis was a bad Protector, did they overlook something?
Thanks again guys.
Old 07-10-2010 | 05:54 AM
Pitik's Avatar
Default PS
The compressor belt is running too, despite all this.
Old 07-10-2010 | 06:33 AM
Check if fuse #1 (underhood box) is blown.
Does the idle rpm increase when you press the button? If not, unplug the pressure switch and check that it is closed (near zero ohms between the two pins on the switch). Then plug switch back in and see if the voltage at the wires (either one to ground) on the pressure switch changes. It should be near battery voltage with the A/C button off and near ground with it on. (Not shown in the diagram, the blue wire to the pressure switch comes from the control panel and is the command to start the A/C.)
Old 07-10-2010 | 09:07 AM
If the cabin blower/fan also does not work, then check 10A dash fuse 14 as well.
Old 07-10-2011 | 07:47 AM
hondaciv91's Avatar
I have a 2003 civic lx and the a/c is not working either. The a/c light comes on, the fan is still blowing, but the air is just not cold. I replaced the a/c air filter and recharged the system, but still no go. I also checked all the fuses as described previously. When i push the button, it seems as nothing turns on because there is no increase in rpm nor noise of a/c. any ideas would be great, thank you!
Old 01-11-2019 | 03:04 PM
الفرزدق نور الدين's Avatar
Default Thanks
[QUOTE=RonJ;725108]A bad thermal protector would prevent the compressor clutch from engaging but not the condenser fan from running. Does the fan fail to run? Does the compressor clutch fail to engage? Do both not work? Does the A/C button illuminate when pushed?
. Thank you very very much.. Problem Fixed...your wiring diagram was helpful..........
Old 07-13-2021 | 08:43 PM
Retarmywarrant's Avatar
[QUOTE=الفرزدق نور الدين;798159]
sorry to revive an old thread, but can you post what you did to fix your problem?
matt701
23
09-25-2011 12:00 PM
slx96
08-05-2010 12:35 PM
ex-r
07-19-2010 02:35 PM
nasoj007
08-10-2009 07:11 AM
bodean
11-04-2006 06:00 PM
