2002 Civic Thermal Protector help.
Hey everyone I have a 2002 Civic and I am changing my thermal protector and I have a question. To make a long story short me and my friends were on a cross country trip in the middle of summer when my AC stopped working. I figured out it was the thermal protector. So what I did was just the end connectors off the thermal protector and I think the other end goes to the AC button in the car when it is pushed it tells the compressor to turn on. Is that correct? But i guess my real question is I want to fix it the right way I ordered the thermal protector but i lost the end that plugs into it. Does anyone know if I can order that connector end? I tried calling the dealer but the guy didn't know what I was talking about. Thank You!
When i cut the connector of the thermal protector it had 3 wires. 2 smaller wires and one bigger (fatter) wire.
So if i buy the thermal protector set part number 38908-PLM-A11 that goes into the compressor right? I need that and then whatever plugs into that do you know where I can get that?
So if I order that part it bolts to the compressor and that will take car of the compressor side correct? And I will need to get the connector that plugs into that plug. And that connector basically runs into the car and is controlled by the A/C button am I understanding that correctly? If that is correct thats what I was thinking trying to find a junked car and cutting it off. Thank You
ac thermal protector
also did you change the shim for ac clutch? also this thermal protector has 3 wires 1 big fat and 1 medium and 1 small? i know medium and small wires connect to ac compressor how about the big fat long wire is this connect to fan driver side?
if you are looking for the connector that join the thermo on comp to wire on rad support. they are the same on older civics , just reversed. gray one pin. I bypassed my thermo by using a male end from 96 civic brake fluid cap and gray one pin from same car.
CBaura90
09-05-2019 07:01 PM
keloke2002
07-10-2012 08:44 PM
gbalasn
06-05-2009 07:05 PM
chenhc
04-22-2009 06:30 PM
