2001 civic no spark pleasehelp
Old 08-26-2008, 02:08 PM
Originally Posted by mk378
To check if the belt has jumped, it is not necessary to take out the crank bolt, etc. Simply take the upper plastic timing cover off, leave the lower cover in place. You will need to loosen the valve cover and lift it up to get the timing cover off. Rotate the crank counterclockwise, the way it normally turns, to TDC (single mark on the accessory pulley). Examine the marks on the cam pulley. If the "UP" is down, turn the crank exactly one turn counterclockwise back to TDC again.
mk is right. Only the picture I originally posted of the TDC position of the camshaft gear/pulley pertains to your particular situation. Here's how the crankshaft pulley looks when positioned at TDC:
Ryans2kidz
02-12-2013 07:35 AM
techsol
10-21-2011 06:14 AM
stephelton
01-05-2007 11:10 PM
Kenneth Ames
11-07-2006 09:50 PM
Quick Reply: 2001 civic no spark pleasehelp
