2001 Civic daytime running lights stopped working
RE: 2001 Civic daytime running lights stopped working
I just checked the relay behind the glove box and sure enough the diode was fried. I took the module next to the steering column out and noticed two solder joints looked like they were cracked so I resoldered them. Now to find someone to sell me a diode.
Update: picked up a multi-pack of diodes from The Source-Circuit City(Radio Shack). In order to orient the diode in the proper direction, looking at the relay with the two silver prongs facing you make sure the cathode(k) is on the left. Thanks again.
Problem Solved!
I really appreciate the ideas generated on this issue.
My problems started with buzzing behind the glove box and an intermittent DRL warning light that I silenced by turning my headlights off. Eventually the buzzing stopped and the DRL warning light was solid and the daytime running lights were inoperable.
I followed suggestions and cleared the cold solder joints in the Daytime Running Light Module but still had the DRL light on my dash and no daytime running lights.
I traded out the DRL Relay located to the left of the glove box but the problem persisted.
I then checked the fuses located below steering column in the 01 Civic it is a 7.5 Amp fuse #12 and a 10 Amp fuse #3. Fuse #3 was the culprit and now the Daytime Running Lights are working perfectly with no DRL warnings.
It appears after reading many threads on this subject there are multiple points of possible failure in the circuit. Module (located to near the Hood release - Grey Box) - Fuses in cabin below steering column - and a relay located to the left side of the glove box (Grey Mitubishi Part RC-5102). It is less likely to be a problem in the headlight switch or parking brake but stranger things have happened.
I think the buzzing noise was intermittent power to the relay by the glove box but was only a symptom from the module power issues.
1. Bad solder joints in the DRL Module eventually start causing the DRL relay to chatter.
2. The chattering DRL relay eventually causes the DRL relay coil snubber diode to short out.
3. The shorted diode causes the 10 Amp DRL to blow.
You need to fix the bad solder joints first or else be prepared to do it all over again with replacement fuses and relays.
For additional information search for "Full Meal Deal".
Last edited by civic2001; 03-14-2013 at 02:09 PM. Reason: Insert search string "Full Meal deal"
YAZZZZ #3 Thank You so much for posting this!!!!!
Great. Ditto. Thank. U all. All good input. On this matter. And. A merry Christ~Mas. Too u all
Clyburn13
04-14-2009 09:59 AM
bpcorliss
08-15-2008 11:10 AM
