2000 ex coupe erratic idle issue?
Have you even hooked up an accurate tachometer to measure the idle speed when the engine warm?
we also didnt have a tachometer so we couldnt check the idle speed.
When you have an idle problem, you need to be able to read engine rpm. Do you have access to an OBDII scan tool? Some can read engine rpm.
Have you checked the ignition timing with a timing gun?
slipped my mind but when car has been sitting for awhile, and you first put it in 1st gear, it kind of hesitates the first few hundred yards down the road in 1st and 2nd gear.......step on the gas and it doesnt want to go anywheres. after then its fine.
not sure if this is related but it has started recently also.
again, no codes.
again, no codes.
Was the timing checked with a timing gun?
