2000 civic probs
Old 05-20-2010 | 03:37 AM
fishindude911's Avatar
Default 2000 civic probs
ahite well my auto tranny went out, and i had a 5 speed swap done, now when im going down the road the speedo will bounce around and the check engine light stays on and theres some plugs around the manual tranny that theres nothing to plug them into since i did the swap. is there and electrical components that need to be changed since i changed the trannys out, any info on these probs would be greatly appreciated
Old 05-20-2010 | 04:47 AM
Speed sensor plugged in?
Pull codes and post results also. The more knowledgeable members will need this.
Old 05-20-2010 | 05:01 AM
You need to change the ECU too or the CEL will come on because the ECU that came with the car is still expecting an automatic. But that doesn't mess up the speedometer. :Like Nike said, check the speed sensor plug also check for fuse 15 problem which cuts power to the sensor. If the speed needle bounces around but the odometer keeps rolling properly the problem is the speedometer head itself; the same sensor circuit runs the odometer so it would be OK.
Old 05-20-2010 | 08:38 AM
does anyone know where i can get a ecu at and how much is it gonna run and how would i know which one to buy, the guy said that the tranny came out of the same year model car how would i figure this part out. thanks for all your help, and ill check on the codes
fishindude911
05-07-2010 01:30 PM
Civic Chix
01-03-2008 03:10 PM
ThatGuy20
10-10-2007 09:35 PM
finalimpact
05-24-2005 07:52 PM
Amanda
02-22-2005 12:39 PM
Quick Reply: 2000 civic probs
