2000 Civic EX stalled and won't start. checked for spark, compression and fuel
I have a 2000 Civic EX Coupe, with a D16y7 with about 120K (original D16y8 was siezed)
So a couple days ago, on Thursday, I was driving into a parking lot and the engine mount that bolts into the timing belt cover broke, and my engine fell. It never hit the ground (was about 2 inches away).
I parked right away and shut off the engine. Used a jack to lift up the engine, and found that the bolt snapped (it was only on one bolt instead of two)
I went and got a replacement bolt, fixed it, and started the engine.
Everything ran fine, everything was perfect. I started driving and after about 10 min (3-4 miles) my engine stalled. I rolled into a gas station and it won't start every since.
I towed the civic home and can't get it running. The engine cranks, I have spark, I have fuel pressure (recently replaced the fuel pump, and I hear it prime, also spark plugs have fuel on them), I have spark (took a spark plug out, and grounded it, it sparked), I have compression (not the best, but its consistent between cylinders at 110 psi)
I checked all my fuses, and ran an OBDII scanner, no codes or check engine light. At this point I'm clueless and need help.
Any other things I can check?
Help would be apprecieted.
Thanks!
Thanks!
Smuteye
06-15-2011 07:13 AM
tchongtching
05-05-2011 09:37 PM
Aeon_Blue
08-03-2010 05:40 AM
her98civicex
06-04-2010 11:48 AM
