2 Sets of New Headlights Burned Out
I replaced my headlights about 3 weeks ago in my 1997 honda civic dx. They worked fine until yesterday when both the low beams burned out. The high beams worked for 15 more minutes and also burned out. So i picked up a test light to make sure the the switch on the steering colum was not faulty. The fuses for lows right and left and highs right and left were fine. I also unplugged the bulbs and tested the plugs which also had power. I replaced the 30amp fuse under the hood just in case. They guy at pep boys let me exchange the lights with no receipt and I installed them without touching the bulb this afternoon. They worked fine. I drove the car tonight and halfway through the drive the lows burned out. Turned on the highs and not more than 30 seconds later they burned out too. I had 1 old bulb in the car to replace one light. It got me home and did not burn out. Both sets that burned out are Sylvania High Blue lights ($30) a set. Not cheap stuff. My question.... Is it a short or a surge? Replace the alternator where the regulator controls electrical output?
Thanks,
Max
Thanks,
Max
SIMPLE..... you touched the glass bulbs.
DO NOT TOUCH THE GLASS.... the oil from your hands will create hot spots on the glass and they blow really easily!
so just change the bulbs and NEVER touch the glass on the bulbs only hold it by the plastic wire plug. if you touch the glass by accident then use some alchole and wipe the bulbs down good and let dry before you try again.
Check the voltage at the battery with the engine running. More than 16 volts is definitely overcharging, in the 15's isn't so good either. You will have short life of bulbs, the battery, and other electrical parts.
Lightsped
08-12-2008 11:59 AM
PhilStubbs
08-27-2005 11:07 AM
