1998 civic will not turn over
Old 06-07-2007, 04:42 PM
Default RE: 1998 civic will not turn over
Did this problem exist before replacing the battery? Did you just replace the battery hoping it would fix it, or was there some other problem with the battery?
Since the starter turned, your connections are good. If it did work before replacing the battery, it is probably the anti-theft system (if equipped) or some other "software problem." You could try disconnecting the (-) lead of the battery again for a while to reset the various computers. Also consult the manual or a dealer about the anti-theft system.
Also you could try jumping the starter with the key on now and see if it will start. If the anti-theft system is active, it probably won't. If it is a switch or relay problem, it should. You really really should have an assistant in the driver's seat to shut it down if there is a problem.
Old 06-08-2007, 04:55 AM
lasombra's Avatar
MK378 Thank You...well thought out..I agree....will jump starter to try to start today......this problem was caused by someone checking the battery terminals and airbox.......the battery was replaced AFTER the problem....hoping to solve it....will report back with any Solution...thanks ALL
Old 06-08-2007, 05:44 AM
2slo4u's Avatar
I agree with mk378. If your light are flahing then it might have something to do with your alarm. Do you have an after market alarm? You can unplug the brain of the system and it might start. Thats what i had to do.
Old 06-09-2007, 02:49 PM
lasombra's Avatar
Same....will not turn over.....hearing fuel pump come on and strter relay.......
1 jumped starter in car....with key on ignite....starter spins good but solenoid deos not engage starter gear
2 removed starter and had starter bench tested....works perfectly....solenoid kicks out starter gear perfectly with starter out of car....
3 continued to check relays wiring and fuses.......nothing??????
4 Car doesNOT have an alarm system
5 this problem originated when a woman ( no offense) removed battery cables and airbox to check whatever?........no previous problem.......installed NEW battery after problem.....?????????no effectWTF.......neutral saftey switch at shifter??...going there tomorrow.........Thanks all......again.
Old 06-14-2007, 04:01 AM
lasombra's Avatar
Guys....Once again thank you all.......thereWAS an ALARM SYSTEM.....that was the problem.......live and learn.....great board good luck....what a great response from you all!!!
Old 05-19-2009, 10:55 AM
timjtitus's Avatar
what did u do to fix the problem with the alarm?
rrmallis
04-12-2012 07:32 PM
BrownRice
03-06-2012 04:56 AM
youngfreshwun
03-30-2010 08:40 PM
drumforever
05-28-2009 06:18 AM
jeffskw
10-03-2008 03:58 PM
Quick Reply: 1998 civic will not turn over
