1997 civic ex has no spark
Old 08-11-2005 | 10:48 PM
onetrackmind's Avatar
Default 1997 civic ex has no spark
Hello, new to the forum, I have a 97 civic ex that died on the way home from work. Had it towed home and started t-shooting. I have no spark. I am using a haynes manual to t-shoot. I have power to the coil and the ICM . All resistance readings are within tolerance on the distributor. I changed the ICM but that did not help. Also put on a new cap and rotor. Any input would be appretiated.
Old 08-12-2005 | 02:40 AM
97CivicEX's Avatar
Default RE: 1997 civic ex has no spark
do a search:
https://www.hondacivicforum.com/m_82923/tm.htm
for him it turned out to be a bad coil.
Old 08-12-2005 | 07:03 AM
maachan513's Avatar
Did you check timing belt? Maybe rotor is not turning...
Old 08-12-2005 | 09:00 PM
Yes the timing belt is the first thing I checked. Also the coil resistance ck is good. any help is appreciated. will post when I get it sorted out.
Old 08-13-2005 | 10:34 AM
maachan513's Avatar
Does your Honda has crankshaft position sensor? The sensor may have moved too far from the trigger and the system doesn't know if the motor is turning,,,,,,,. I am not all that much familiar with automobile ignition system and my '90 Civic has not given me any problem in this area. I'm just guessing ,,,,,,,,,,,.
Old 08-13-2005 | 08:35 PM
thats worth a look, thanks.
Old 08-14-2005 | 09:58 PM
good news. the car is fixed and it was the coil. I could not believe it. A lesson to anyone who has the same problem and reads this thread. Even if the resistance values are within tolerance, the coil can still be bad. That is exactly what I had, a coil that metered good, but was bad. Thanks to all for your input and help.
Old 08-14-2005 | 10:10 PM
maachan513's Avatar
Did the coil have short to the ground? And yet giving your the reading correctly? I am confused and surprized
Old 08-15-2005 | 05:59 PM
No there was no short to ground. With resistance measurements you only need one strand of wire to have continuity. So something else was wrong that did not show up with a multimeter.
Old 08-16-2005 | 08:59 AM
maachan513's Avatar
Hi,
If you had the coil checked out ok in the begining of troubleshooting, you must have gone thrugh every other components. How did you find out that the coil is bad in the end? Did you gamble? And bought new unit?
Please don't think that I'm nosy for asking.
