1995 Civic DX Fans not spinning.
Old 04-13-2007 | 05:45 PM
Blammo300's Avatar
Default 1995 Civic DX Fans not spinning.
About a month ago my 95 Civic overheated and was leaking coolant. I used some Radiator Stop leak and put some new coolant in the car and it stopped overheating.
Last night the car overheated again and started leaking Radiator fluid, but this time not as much. I noticed though that niether of my Radiator fans are spinning. I tried the Radiator Stop leak stuff again and I drove my car for 20min today without the gauge going to the H, however my fans still are not on.
Could the fan issue be a fuse problem?
Old 04-14-2007 | 05:57 PM
Roadkillboy0's Avatar
Default RE: 1995 Civic DX Fans not spinning.
i dont really know much about radiators or stuff but i think you probably might need a new radiator. also check the electrical connection for shorts and stuff...sorry i couldnt be of better help. the reason i say that is because your radiator had a leak in it
Old 04-15-2007 | 05:55 PM
shoobie's Avatar
I had the same symptoms recently...the fuse for my cooling fan was blown. Cooling fan fuse is located in box under the hood. Might also be the cooling fan relay (also located under the hood).
theTAHK
12-10-2011 12:00 PM
blacksol
12-17-2007 07:08 PM
simmeth
08-15-2007 03:00 PM
ccarey
05-24-2007 09:53 AM
Talon585
09-21-2006 10:21 PM
Quick Reply: 1995 Civic DX Fans not spinning.
