1993 honda civic dx help smog
Old 04-06-2009 | 11:30 PM
churritos567's Avatar
Exclamation 1993 honda civic dx help smog
i took it to get smogged today and they didint want to doit because my check engine light wasnt hooked up. i found a couple thinks i will post picture asap but can anyone give me an idea of what to find to hook up my check engiine light there charging me 80 bucks for them to tell me whats going on with my check engine light hookup
Old 04-07-2009 | 05:29 AM
Pull out the cluster and check for a removed CEL bulb or wires cut at the rear of the cluster.
Also check for wires cut at the ECU connectors.
Old 04-07-2009 | 07:18 PM
turkeysandwich's Avatar
Also, I don't think you should pay 80 bucks for them to run a diagnostic, you can get a decent reader for 100 dollars.
Old 04-08-2009 | 07:38 AM
A 1993 has an OBDI system which means the cheap generic OBDII readers won't work with it.
You either need to fix the bulb so codes can be read out via the CEL blinking, or have a Honda-proprietary OBDI reader.
Old 04-13-2009 | 07:40 PM
thank ronj your the best there was no cel bulb on the check engine now im going to scan it now because it is stayin on thank you so much you guys are great
Truespiritfit
02-21-2012 10:05 AM
churritos567
12-06-2010 08:38 PM
buster84
03-19-2008 02:11 PM
91hatch88
07-07-2006 03:24 AM
bem93080@hotmail.com
07-02-2006 08:22 PM
