1992 Civic cx thermostat
Old 09-05-2009 | 06:25 PM
budeelee's Avatar
Default 1992 Civic cx thermostat
Just trying to find out which thermostat I need for a 1992 Civic CX 1.5l D15b8 with a manual transmission. Rock auto offers 4 different temps.195 deg , 192 deg. , 180 deg. , and 170 deg.Also they have slightly different diameters available. If you know anything about this the help would be appreciated. I am doing a timing belt,tensioner and water pump change soon so I figured while I had the coolant drained I'd do the thermostat too.Thanks
Old 09-05-2009 | 09:17 PM
well since you live way up north i suggest a 192deg so you will have good heat for the harsh winters.
Old 09-06-2009 | 09:04 AM
Use the same temperature as stock, I think they are all 195. When you get the old one out, it will be marked with a temperature, possibly in degrees C which you'd need to convert. 192 is close enough to 195 not to worry about it.
robzombie
15
01-15-2012 04:36 AM
Tinkerrat
02-04-2011 04:16 AM
d0ubi
01-19-2010 03:25 PM
Flybye
12-31-2006 01:41 PM
dimaguila1
03-03-2005 12:28 AM
