1987 CRX HF has significant run on issues.
Old 04-02-2005 | 04:10 PM
pred8tr's Avatar
Default 1987 CRX HF has significant run on issues.
I just picked up this 1987 Honda Civic and one of the things that its doing is running on pretty long after I cut it off. Additionally the gas milage is really not where it should be. The odometer doesn't work but I've done the math recording where I've been and I estimate I'm getting about 15 mpg. I've been running 87 octane in this car. Additionally, what are the octane requirements of this engine? I've been running 87 octane. Do I need to run higher?
Thanks all.
Old 04-19-2005 | 12:30 AM
bradcoonsracerx's Avatar
Default RE: 1987 CRX HF has significant run on issues.
well i am hear to answer ur prayers lol im pretty much a hinda technichian if built like several 9 sec civics in my time which im only 20 but i have a lot of knowledge not to many people can answer the questios that ic an so i will help u.......it does not requir 87 u need to run ethenol that will straighten n clean ur system out , ur engine problems might be caused by injectors i would go with 1300cc njectors on ur internals with a fuel pressure regulator hks adjustable n a walboro 255 fuel pump this will undoubtly straighten ur cars problems right up my technical advisor (billy gray ) also suggest jus ****n gettin rid of that motor n puttin a mac truck engine in he said its almost a direct bolt in u can put th eintercooler in ur trunk or on the roof for the ultimate performance set up ull be running 9s in no time he said cummins diesel turbo r the best 2 so think bout it
Old 04-19-2005 | 12:59 AM
StifflersMom's Avatar
Cat Fuсker
ORIGINAL: bradcoonsracerx
Why don't you go play in the sandbox?
Old 04-19-2005 | 08:27 AM
sacicons's Avatar
is your car carburated?
Old 04-19-2005 | 01:10 PM
se7ensectoolate's Avatar
Please die.
Old 04-19-2005 | 01:33 PM
Super Mario's Avatar
I believe all cars after '92 are pgmfi or mpfi or dpfi, but deffinatley not carbureted.
ORIGINAL: sacicons
Old 04-19-2005 | 08:18 PM
AOL.COM's Avatar
a honda gettin15 mpg? ive got a7000 lb gm van gettin 12 mpg ---trade the 87 in for a 97 ---or u could let it "run on " into the river[:@]
Old 04-20-2005 | 12:20 AM
sacicons's Avatar
ORIGINAL: Super Mario
ORIGINAL: sacicons
Ummmm. Mario? its an '87.
Old 04-28-2005 | 08:47 AM
justbob74's Avatar
Might want to check your timing. Replace the belt to if you just picked it up and don't know when it was last changed.
Ed Fisher
03-02-2010 08:42 AM
Faraway
01-03-2009 11:08 AM
stephmk
02-26-2008 03:09 AM
Da Chump
03-21-2007 10:31 PM
pred8tr
04-01-2005 09:01 PM
Quick Reply: 1987 CRX HF has significant run on issues.
