05 Honda civic EX Special Edition Radio
I have the 6 disc cd player and i am trying to take it out I have been searching a long time and cant find anything. Also can i connect an amp straight up to this stereo or would it be best to buy a new one?
then you need a one channel amp that will receive the signal from the head unit and a capacitor to put between the battery and the power for the amp the subs hook up to the amp normally the manufacture of the subs will recommend what gauge wire to use to the subs and the amp manufacturer will recommend something to get the power to it. the back of the head unit should have a red and a white plug this is the signal output that your going to send to the amp.
http://www.rockfordfosgate.com/rftech/rftech.asp
this is a great site for help setting up a system you should check it out befor you continue
jd352
04-24-2007 09:41 AM
diablo69
07-18-2006 10:50 AM
AlpJLFan
08-03-2005 08:15 PM
