02' Civic Overheating Problem...
Hello everyone,
I have 02 Honda Civic EX. Recently, it starts to overheat and I tried many possible ways to fix it.
Overheating causes over-pressure and that causes water ejection from reservoir.
I did:
1- Changed the radiator cap
2- Changed the reservoir(the plastic thing)
3- Changed the thermostat
4- Changed the switcher for fans
As far as I know, there are several possibilities left:
1- Head gasket
2- Water pump
3- ??
At last, my mechanic took the thermostat over and told me to drive without it to see if it overheats again.
Well, it overheats again but the one thing I noticed it did not eject water from reservoir or anywhere else. Without thermostat, I did not see any bubbles in the water tank, BUT it overheats after 15-20 min.
So, what is your suggestion? Any idea will be appreciated..
Edit:
One thing I need to mention also is that the car is only overheating when I go into slow traffic or idle. While I drive with 75+ mph, temperature looks just fine.
Thanks in advance..
I did:
1- Head gasket
2- Water pump
3- ??
Edit:
Thanks in advance..
First, thanks for the response.
Even though the switch has been changed recently, fans are not working properly IMO. When the temperature gauge goes high a little, fans sometimes start working and sometimes not. It should work until it gets cold enough.
Therefore, I drive with AC turned on(to make sure fans are coming on), however, it overheats again.
Actually, I had pressure tests done in 3 different mechanics. All of them said there is no external leaking.
I follow the procedure in this video to see if head gasket is blown:
Head Gasket Check - YouTube
And yes there are air bubbles coming from the radiator just like in the video. I don't know if it is the only reason for air bubbling.
Joelt624
16
02-21-2020 12:59 PM
quadlow
10-20-2011 04:57 AM
michigan245
05-04-2011 11:04 AM
SilverCivicDX97
07-12-2010 11:44 AM
trebor_2005
05-19-2006 01:40 AM
