01 Honda CIVIC EX 5speed clutch noise
If you were to pull the clutch lever back, pressing the piston into the slave cylinder more, the throwout bearing would move away from touching the clutch cover so it would stop turning. Then if the noise continues, you know it's inside the transmission.
Make sure the transmission has enough fluid. Manual transmissions are filled with oil or Honda's manual transmission fluid. There is no dipstick, you need to unscrew the plug to check.
Pablobobatty
12-19-2013 12:17 PM
SACUSTOMS1
04-15-2007 04:24 PM
artrusli
12-01-2004 02:59 AM
