01 civic bogging/stalling
Did you clear the ECU of old CEL codes? Has the CEL turned ON since this time? If so, what codes were retrieved from the ECU? By the way, all of this can be done with an inexpensive OBDII code reader or by AutoZone for free.
No I never got around to it. I will do it this week.
The CEL appears and disappears randomly. Right now, no CEL. Yesterday, it was on. When I bought the car in May, previous owner told me that he had a OEM spec aftermarket brand cat welded in, since Honda wanted to replace the whole exhaust system ($$). Would this make turn the CEL on and off like it does?
Does your car stall every time you turn off the engine and start it back up?
Does it stall on every gear?
Does it stall only when it is cold?
If yours does it consistently on all gears, different speeds, and weather, it may be possible that you have a clogged fuel filter.
Mine only does it in first gear when I first accelerate moderately on a cold day. It has done it intermittently in the past month but today it has been consistent. It would stall and then start bucking for awhile until I let off the gas and accelerate again. It would be fine until the car sit for awhile and I start it up again.
hatchback virgin
01-04-2009 04:00 PM
Ruester
07-17-2008 02:24 PM
clong0812
05-01-2007 07:03 PM
dragoth
03-14-2007 04:59 PM
