Burn I-tunes music to C.d?
Old 04-23-2007, 05:35 PM
mill$civic's Avatar
Default Burn I-tunes music to C.d?
I want to get I-tunes and burn the songs I download to a c.d to play in my car. Can I do this, you does it download the songs in a special format only for i-pods?
Thanks
Old 04-23-2007, 05:41 PM
skateman190's Avatar
Default RE: Burn I-tunes music to C.d?
no there should be an icon in the bottom right corner of itunes that u can burn a cd
Old 04-23-2007, 05:42 PM
Eun's Avatar
Eun
Eun is offline
eh. so you downloaded musics from itunes?
I never did it before, so I don't know, but if it's original file, you can burn it in itunes...(they actually have the option there I think)
or you could get another burner or something...
just becareful when you're burning, you got a slow computer, the music ends up REAL BAD.
Old 04-23-2007, 05:51 PM
yeah just select the files from your library and there should be a little icon in the botoom right like i said that should work
Old 04-23-2007, 06:04 PM
Fiirkan's Avatar
^ you are leavein out the point that you need to create a playlist and then put the music that you want in that playlist, THEN there will be an option in the bottom right that says "Burn CD" be sure to set it as audio CD under the burning preferences, by going Edit> Preferances> Advaced> Burning. it is defaulted to that but check it to make sure.
Old 04-23-2007, 06:16 PM
good point, my bad
Old 04-23-2007, 07:41 PM
mill$civic's Avatar
I cant justtake thesongson my computer after I d/l them from i-tunesand use a different burning program?
Old 04-23-2007, 09:34 PM
as far as i could find out by trying you have to use i tunes to burn it, you could use limewire or sumthin and then use a different burning program but i dont think you can use others from i tunes
Old 04-23-2007, 10:26 PM
mybrokenblinker's Avatar
It's really easy to use i-tunes to burn so I don't know why you'd really want to do something else. There might be a reason you just haven't told us, but if not, just drag and drop them in a playlist and then hit the burn button, that easy.
Old 04-24-2007, 11:40 AM
Fiirkan's Avatar
ORIGINAL: mill$civic
I cant just take the songs on my computer after I d/l them from i-tunes and use a different burning program?
If they are bought from the itunes store then no, unless you have another burning program that supports M4P format. iTunes is pretty easy to use for making CD's though
Quick Reply: Burn I-tunes music to C.d?
