umm yeah dumbass move....
Old 12-06-2006 | 12:10 PM
n8te81's Avatar
Default umm yeah dumbass move....
ok so i was taking off my old el glow gauges so i could put the news on i got from speedhut on...i was sliding the old ones off since i dont have the needle tool and the temp needle went to where it was going all the way around so i barely lifted up the stock gauges so i could see what happened and the effin needle BROKE OFF!!!!! dammitt.I know that was a stupid thing to do but i didnt know it just barely on there cause i didnt even put that much pressure on there......so is there anything i can do or is my retarded *** gonna have to buy a new one???
Old 12-06-2006 | 01:09 PM
ej6buddy's Avatar
Default RE: umm yeah dumbass move....
try getting model car plastic glue, and try to reattach it or something, never hurts to try????
Old 12-06-2006 | 01:26 PM
n8te81's Avatar
yeah thats what im trying right now.....if i cant get the temp needle back on ill just have to glue it on there for now....i dont have the 100 bucks to go to the salvage place here and get a whole used one....
Old 12-06-2006 | 02:03 PM
n8te81's Avatar
well just glued it on there for now ill just have to check my water and everything now more often....i can get the temp assembly from the dealership for 26 bucks so ill just get one later on and have them do it.
Old 12-07-2006 | 09:36 AM
FlipHKD720's Avatar
i did the same thing except my needle didnt break, it just came out. Now that i put it back in, it doesnt even work, so idk man, good luck with that.
Anyone know how to fix a needle that out anyway? Its back in there all right but it wont turn or nothin (this is for the Engine Temp gauge).
Old 12-07-2006 | 12:37 PM
sandrider123's Avatar
So I did the same exact thing. I called the stealership to ask them about it they said it costs like 90$ to fix it. So since I plan on keeping the car I bought a new guage cluster from a junkyard. When you install the guages just place them on top of the factory ones you dont take the old faces off. It just creates alot more hassle.
Old 12-07-2006 | 02:09 PM
n8te81's Avatar
well see thats the thing....the old ones were in 3 pieces unlike the new ones from speedhut which is just one big *** piece....soooo you have to try and put it on all at the same time and if your by yourself its a pretty big pain in the ***.The temp had something keeping it in place or something so if you look its the only one that doesnt have a stop pin.....So if it comes out or breajs your pretty much screwed on that deal.....EFFIN SUX!!!!!
Old 12-08-2006 | 11:24 AM
The speedhut gauges are just one big piece?
Old 12-08-2006 | 12:51 PM
n8te81's Avatar
well yeah kinda....they are all connected,not like the other ones i had that were 3 pieces thats what made it alot easier to put on but the ones i got from speedhut were all connected so that made it a bitch to get on there if you dont have help which i didnt..
Old 12-08-2006 | 02:56 PM
dang solid piece.... that sounds imposible to put on due to the temp/gas gauges.
but for cheaper just keep looken on ebay for a used set.......
i only paid like 26bucks for my cluster.... tho i snaped the needles off the temp/gas needles, the MPH needle and painted over the tach.LMFAO
just look on ebay and buy a new set....
o and this time I GOT A IDEA FOR YA.......
take apart the cluster!
the tach, speedo, and tach/gas are three seperate instruments... simply remove the silver screws from the rear of the cluster and the face and electronics should simply slide out of the front with the small black bezel removed also...
then you should be able to twist around the new face overlay around to get it onto the temp/gas gauge needles first then slide it over the speedo and then the tach.... that should make it ALOT EASIER to instal a solid overlay!!!!!!!
just be carefull puting all three units back in very carefully so ya dont pull on the needles any....
Quick Reply: umm yeah dumbass move....
