Some Q's about Projector Headlights
Hey just got a 2000 Civic Si (Ex in the states) and picked up some prjector headlights. I do not have HID's but when I took a look at the headlights the plug that looked identical to the plug that goes into my current hallogen bulbs was hanging looks and there was another wire with a bulb in the projector section of the headlight(where I assumed you could put the halogen). Anyways I dont want to start ****in around with them and figured Id check to see if anyone knew what was going on. I took some pics of the headlights and the wires that i'm talking about.
[IMG]local://upfiles/27148/A9241AF788E74C498210CB5A293780E8.jpg[/IMG]
[IMG]local://upfiles/27148/3D8FE0D9A83D4ABEB2B14B5F83F55D96.jpg[/IMG]
[IMG]local://upfiles/27148/7383C63DE25A4015A42242AD60FDCD94.jpg[/IMG]
RE: Some Q's about Projector Headlights
Yeah pretty much, I have no clue what is what. I know how to install the headlight but have no clue how to set it up(plug it all in). Where would I put the halogen bulb I currently have? The headlights did not come with any explanation or installation intructions.
Hey, I just installed a set of those a month ago. You plug the blinkers directly into the plugs where you detached the old ones. As for the halogens you don't have to keep your old ones, it comes with a new set. It is simple plug and play for the most part. if you can get the old ones out, you just do the oposite to install the halogens
ya i dont see what your talking about....... that is PLUG AND PLAY... unplug your stock headlight bulbs and plug that 3 prong plug from the projectors into it. WIRING DONE.... then just swap the corner/turn signal. for that one just pop it off your stock housing and put it in same way into the projectors VERY EASY!!!!!!!
if thiers HALOs on them then thier will be afew extra wires for the halos but those arent needed. but if you want to wire them into your parking light wires...
HONDA PUSHA
12-30-2004 01:31 PM
