the "shocker" battery tie down
o dam nice......but for a older civic they MIGHT not fit.... with a 92-00 civic the battery terminals are power on the right side. so unless your swaping your battery cables or making your own to lengthen them then the shocker will be pointing away from the firewall if you think that would be on your nerves any...
i know id at least want it to be pointed into the firewall.
otherwise it looks like it will be VERY VERY CLOSE to the positive terminal which is defiantly a very very bad idea!
but you COULD how ever get some threaded rod and bend a hook on one end for the bottom and bend the new rod over so it moves the whole cover closer to the ground alittle. just an idea.
i just wouldnt want it that close to my positive battery terminal.
or you could always just make your own to fit alittle better.
