Seat Replacements
#23
RE: Seat Replacements
I'll do it this weekend.
I did think about crafting some metal bracet extenders that would bolt from the Integra Seat bracketsto my existing bolt holes in the floor but the thoughtoccured to me after I had taken theIntegra seat out.
#24
OK, I got the seats in.
I want to say THANKS to everybody for all the help.
The tutorial on the seat swap the BlackDX led me to was a big help.
I gave me the confidence to know that it could be done.
I started to follow the tutorial but I found a much easier way to swap the brackets. The drivers side seat, inside bracket was the only one that needed any mod. I had to drill out one hole a little larger.
There are two bolts that hold the bracket with seat belt clip and a third bolt that connects the bracket to the back of the seat bracket.Very easy swap.
The door side brackets didn't even need to be removed. The slider part of the bracket is connected to the bracket with two bolts. EASY swap. Didn't even have to remove the two adjuster ***** on the driver's seat. Now they are bolted in correctly with all four bolts.
These seats are SO much more cormfortable than the stock Civic seats. The two adjuster ***** on the side really are a big help but the best part of all is the adjustable lumbar support. Several levels of adjustment.
Here are some pics:
Here are some pics:
kennycivicparts
03-01-2007 05:19 PM
milberndoesit
07-28-2006 07:10 PM
