Sanding down primer
RE: Sanding down primer
get some smooth sandpaper ,about 200ish grit (im guessing you primerd from a gun,mideum build) and a sanding block and just go in long streches across the bumper, your going to sand into the bumper a bit...USE a block, because if you just put your hand to hold the sand paper your putting different amounts of pressure on it..good luck
yes and no. you should be alright but, do you have a automotive paint store around your area. if so go and buy some "HIGH BUILD PRIMER" its in a rattle can too but its automotive primer. same stuff they spray out of the guns. anyway. if not then just go to the store and get some sandable primer but i would put alot of coats on it cause your going to sand alot of it away. anyway use a block to sand and use 320 grit. take a bucket and fill it with water. cold or hot don't matter your puting your hands in it. get a rag. make the rag and the sandpaper wet. use the rag to keep the panel wet while you sand this is called wet sanding. i know duh! anyway sand in the direction of the panel not in circles and you don't have to apply alot of pressure to the block. just keep it wet. if u think of it in a perverted kinda way its kinda like sex......just keep it wet....thats all im saying. good luck
things can be done right with a rattle can. like i said if u have a automotive paint store in your area then go to them and they can put whatever u want in a rattle can. that is if u don't have access to a compressor and paint gun. so just look in your door jam and find the paint code and give it to them they will mix the paint and put it into a rattle can or i better say several rattle cans. you can get single stage paint with clear already in it so when it drys its done. you pervert. [sm=joke.gif]
