Rims
#21
also, if you figure out what wire it is, you could wire them to your dash lights so that they are controlled by the dash light dimmer ****. all the dimmer **** does is take in 12V and adjusting the **** reduces the amount of volts that the lights receive. For this, the wire you will need to tap into is the wire between the dimmer **** and dash lights (in reference to where they are located in the circuit)
#23
wheels go rota i bought a set of slipstreams from http://jlbmotorsports.com/ and have nothing but good things to say about them even when i had to order one to replace a bent one (75mph + basketball sized rock) they are really professional and a pleasure to deal with.... interior lighting (you do not want intense you will be blind trust me on this one) use red because this does not totally destroy your night vision and keep it ambient not direct light (hide the source behind stuff) and you should be ok.... Do not put anything on your car that announces to the world you have modded your car or you will come outside to where your car was and find an empty parking space and broken glass
#24
depends. if you can mount them in the top of the interior door handle housing and point them down, they shouldn't be right in your face.
txedomask433
12
07-15-2007 01:57 PM
icarus
02-12-2006 10:07 AM
