Redoing headliner
There are a few DIY guides in the appropriate section on the forum. It covers how to re-wrap the door panels, sunvisors and center console too.
I have rewrapped my headliner twice already and I am preparing to do it again once I figure out where this water leak is coming from.
Do you have a sunroof? If so, are you planning on wrapping the bottom side of that to match the rest of the headliner, too? You will have to remove the sunroof from the vehicle to do this.
Just pull off the old fabric, spray 3m adhesive on the headliner (only do a small portion at a time) and put on the new fabric. Use a hit glue gun around the edged which the fabric wraps around. I have found it is easier to work from the middle of the headliner out to the edges.
Once you drop the headliner, there should be 8-10 bolts holding the sunroof up. have a friend help support it while you remove the bolts so it doesnt fall onto your head
Also, make sure to pull the little drains off from the corner. You'll see them and it is simple to pull them off. In the DIY for this, I believe it explains on how to remove that portion of the sun roof assembly so you can re-wrap it.
addiction2bass
08-26-2007 05:24 PM
droolincivic
11-24-2004 01:30 AM
droolincivic
08-23-2004 05:06 PM
