Problem with LED install
Old 10-14-2007, 03:56 PM
plethoric33's Avatar
Default RE: Problem with LED install
Alright...I did all the wiring today. I grounded the gold wires on the strips like it said, grounded the black wire on the switch like it said, connected siler wires from srtips to red wire on switch, and wired the red switch wire up to an inline fuse...BUT NO POWER!!! I CANT get the lights to turn on now. How can I get power from the fuse box (in normal english terms) ....? Can I just wrap the wire around a fuse and push it in?
Old 10-14-2007, 04:02 PM
you could wrap it around BUT its not the best idea!!!!!!!!
where do you have the power wire tied into now?
since your using a inline fuse then crimp on a female spade terminal and then find a spade terminal on the fuse box that has power when you want it to... some have power ALL THE TIME... others power with accessory or in the RUN position of the key... i believe the HOT all the time is top far left.......
Old 10-14-2007, 04:15 PM
Well I bought an Add-a-fuse...which looks like this..Name:  SANY0164.jpg
So I tried that on EVERY empty spot im pretty sure...I had it crimped to the inline fuse wire, which is connected to the switch.
Old 10-14-2007, 05:38 PM
o ok... thats different...... with that you add it to a existing fuse.... not a empty spot. cause most empty spots arent wired for power......
style i was talking about is a inline fuse....
Old 10-14-2007, 06:04 PM
I have an inline fuse too. The Auto Zone guy said I should use both. So should I take out the inline fuse and wire the add-a-fuse tothe switch instead? This what I have...The Blue are lights, red is power, black is ground. Name:  diagram-1.jpg
Old 10-14-2007, 11:05 PM
TheMoogly's Avatar
That's a killer diagam
Old 10-15-2007, 12:10 AM
HAHAHA....I know its messy but with MSPaint and 3 minutes thats what I came up with...
Old 10-15-2007, 01:37 AM
ya i would remove the add a fuse crap.... or just plug it into a existing fuse location.....
do ya realy think the autozone workers know what they are talking about.LOL
some may be help..... but hell i knew some friends that worked thier and i just laughed like MAN THEY WILL HIRE ANYONE!
Old 10-15-2007, 11:12 AM
I guess I figured an auto store with an electrical area would possibly know a LITTLE bit, but it seems like the same people who work at Walgreens checkout can get a job at Auto Zone or Pep Boys...haha. O'Riellys near me has smart people though, but they were closed. Ill try today and see what happens.
Old 10-15-2007, 12:55 PM
Ok...I got the set up ok now...mostly. The light on the switch will come on, but the LED strips will NOT come on!!! I dont see what could be wrong. I have the silver wires to the red wire on the switch.
Quick Reply: Problem with LED install
