Paint On Dash Vents
Paint On Dash Vents
I recently Purchased a 96 Hacthback Civic and there is purple and silver paint on the vents, door handles etc. I can't get the paint off is there an easy way to remove the paint? If not should i just replace the vents with some out of a junkyard?
Thanks
Thanks
RE: Paint On Dash Vents
Try using a heavy cloth with rubbing alcohol. I would suggest paint thinner... but im not sure what that might exactly do to the plastic. If paint thinner works, use fiber glass thinner.... real tough stuff! I normally use marine fiber glass thinner... to get 10 yo paint off bricks in five minutes! lol
Yeah i would have to agree with the above. when i bought my lude si (god rest its soul) i had been painted. i spend hours removing paint with paint thinner. its not that bad on plastic as long as you dont leave it on there for long periods of time....like soaking it. It makes the plastic look dull at first but alittle 2001 and it was as good as new. but there were parts in the corner that you could still see and when the vents moved a certain way you could see a slight tint to them. vents are cheap too at a junkyard. so i went and replaced them all for around 20$.
burnindesirez02
09-01-2008 06:19 AM
