mini-project: polished fuel rail
Old 01-26-2008, 09:39 AM
kokasian's Avatar
Default mini-project: polished fuel rail
I picked up a fuel rail and oil pan for my z6 yesterday at Pick n' Pull.
Here's what I'm starting out with
Its raining like hell so I decided to do this. I think everything in my engine bay will be polished by the time i get my motor built
Old 01-26-2008, 10:20 AM
Civic Si 00's Avatar
Default RE: mini-project: polished fuel rail
Cool...what was wrong with yours...Probably looked ugly huh...
Old 01-26-2008, 10:50 AM
im interested what it will look like after some polishing....
i had originaly painted mine black but it looked preaty bad..... and i thought it was a problem when i droped the new motor in so i swaped the one from my old motor back on the motor...
Old 01-26-2008, 12:59 PM
riceburner700's Avatar
polished my z6 rail with a polishing wheel attached to a fixed grinder. it basically just comes out like a mirror but sucks because you have to keep up on polishing the rail every so often or it starts to dull real fast. might be able to dig up a pic of mine
Old 01-26-2008, 01:37 PM
so how about polishing it and then clear coating it?
Old 01-26-2008, 05:24 PM
kokasian's Avatar
I cant get the little rugulator off thats in the left of the first picture. I wet sanded it with 200, 400, 600, 800, and 1000 grit.
Here's after I sanded it
and here's after I put some mother's wheel polish on it
I'll prolly throw some clear on it later. How do I get that reglator off? It seems like a big fiting just screwed into the rail but I cant for the life of me break it loose. Am I missing something?
ORIGINAL: Civic Si 00
Nothing's wrong with the one on my car, I'm just polishing this one to go on the engine I'm building. I'll also do the intake mani, throttle body, and replace all the visible hardware with stainless
Old 01-29-2008, 05:03 AM
i little time and effort kids can go along way... looks good
Old 01-29-2008, 06:03 AM
bakertime's Avatar
Looks nice. I tried this with an intake tube, and failed miserably....it was probabaly a bit too large for the first time. The whole engine bay polished should look great!
Old 01-29-2008, 06:50 AM
kokasian's Avatar
How did you prep it before applying polish? The sanding is what makes the final product look good
Old 01-29-2008, 11:18 AM
well to get that hose part off ITS REALY TIGHT!!!!!! i slaped mine in a VISE.... with a wrench on it and it was tight as hell!!!!!!! tho downfall with that is its aluminum and even if you wrap it in something it could get dented up very easily.... i would say put it on the car bolted down and then try to break it loose.
Quick Reply: mini-project: polished fuel rail
