interior neons
Old 04-30-2006, 09:21 AM
justinwebb's Avatar
February 2010 ROTM
Default RE: interior neons
just run a line from the battery with an inline fuse to a switch to the neons that is what i have always done.....its not a good idea to tap into the fuse box if something goes wring there goes your whole car....
Old 04-30-2006, 12:41 PM
skimmy_jimmy's Avatar
yeah now that i think about it thats prolly a better idea, i just dont wanna end up with about 20 wires comin from tha battery, always makes it look like sheit
Old 04-30-2006, 01:58 PM
here.. in my celica.. should be close enough to the same thing.. you install the neons where you want them.. then run the wires to the transformer.. then cut of the cig lighter adapter thing.. and butt connect that to some wire.. then run that to a switch.. then run it to some to power it.. i ran my to the cig lighter.. just stick it in the cig lighter connector and tape it up good
Old 04-30-2006, 02:38 PM
justinwebb's Avatar
February 2010 ROTM
if you pull too much power off it the fuse for the cigartte lighter will pop so be careful
Old 04-30-2006, 03:42 PM
i mean running the wire into the fuse box with a fuse tap with like a 3 amp fuse, would that be ok? or still a risk of fryin it?
Old 04-30-2006, 03:48 PM
justinwebb's Avatar
February 2010 ROTM
3 amps isn't that much.....how many neons are you using? i know cold cathodes use .7 amps so a few sets of those would be more than that and in my old car i had about 20 sets and i know that regualr neons use more power than cold cathodes
Old 04-30-2006, 03:56 PM
i was plannin on gettin 2 sets of cathodes to start for now... hell maybe 5 amp?
sorry to ask so much i just wanna make damn sure i do it right, my buddy had bad luck with wiring an underglow kit and his car catchin on fire so im a bit nervous
Old 04-30-2006, 08:15 PM
mill$civic's Avatar
im not sure what cathacods are..but if they come so all's you need to do is plug them into your 12v plug thing, cut that thing off so you have the power and ground..and at the top, unscrew it and there will be a glass fuse in there, just buy a inline fuse holder for it and put it near where you hook up the power wire
..last season i had my l.e.ds and neons hook up to like 5 amp fuses, but they only need .5 or 1(which i installed this season) ..and when i had them with 5 it was fine, a little risky mabey..but they should have something to tell you what it needs
PDthree!
02-06-2008 05:32 AM
Kurt8899
01-03-2008 07:56 AM
skimmy_jimmy
04-29-2006 06:45 PM
speedmouse
03-01-2005 06:37 PM
dalifts
12-05-2004 08:52 PM
Quick Reply: interior neons
