Installing white face gauges, some help:)
![Default](https://www.hondacivicforum.com/forum/images/icons/icon1.gif)
Having some trouble here taking out the bezel. The only screws I found that are holding it inplace are the two small ones, screwing vertically over the instrument cluster side by side. I used little knifes to pull the entire plactic setup with the vents and all, but theres something backthere holding it. Any one ever done this before, or can tell me what I need to do to take it out? Thanks.
Just pull, there's clips holding it in there. Mine has two at the bottom. I'd imagine yours can't be far off.
Edit, I guess yours is pretty different. I doubt it's anything more than clips though. Try taking off the panel below that, around the steering column, and look for screws holding it in from the bottom.
It wasn't that lol. Thanks for the advice however. I had to pull my hazards button, then under that, theres a hidden screw. After that, the whole assembly pretty much pulled right out. Took about 2.5 hours, but after all said and done the glow gauges look sweet! I'll post pics once i get the turbo and all done in the next few days hopefully.
FasterImage
06-13-2006 10:52 AM
fast93civic
02-26-2006 12:35 AM
dadax2
10-22-2004 09:08 PM
