HID bulb question
Old 04-04-2007, 10:04 AM
[meeek]'s Avatar
Default HID bulb question
ok so i browsed the other HID posts and didnt see anything related to this, so...
are HID's universally interchangable? Like i wanna get the Oznium kit, but I saw some HIDs in an Acura 3.2CL (2001ish, somewhere between 10000k-13000k bulbs) that i liked. would they work with the kit?
Old 04-04-2007, 10:16 AM
mill$civic's Avatar
Default RE: HID bulb question
The bulbs? No..you need the bulb type (number)that fits your car like H1,H3,H4,H7,H11,9004,9005,9006 and 9007.
Old 04-04-2007, 10:19 AM
[meeek]'s Avatar
ah, ok. so even if i got an aftermarket kit, i would still need to get...9006's...im guessing.
Old 04-04-2007, 10:22 AM
mill$civic's Avatar
Whats your car and year?
Mabey someone can give you a bulb number you need to buy if you dont no it.
Old 04-04-2007, 10:24 AM
[meeek]'s Avatar
i have an 06' (one of these days ill get a picture up). i was told they use 9005s and 9006s (im guessing the 9005s are for the daytime/high beams)
Old 04-04-2007, 12:00 PM
TheMoogly's Avatar
Just take the OEM bulb out and look at what it says on the side.. that is the quickest way to find out... Alot of 7th gen aftermarket housings take H1 bulbs and OEM housings are like H3 . . . for an 8th gen you really just have to either take out the bulb or look at your manual... that is the only size bulb you can put in that car because it wont securely plug in.
Old 04-04-2007, 01:16 PM
[meeek]'s Avatar
sweet
thanks for your help guys.
Old 04-04-2007, 03:59 PM
cderalow's Avatar
also, the higher the K rating, the bluer the lights look
stock acura is somewhere in the 5-6k range I think
Old 04-05-2007, 01:27 PM
[meeek]'s Avatar
the one i saw was more of a purple color, and it was HID's in regular headlights (not projectors) and it looked neat. though a lot of people rant and rave about how BAD10000k-13000k bulbsare, as far as visibility. i think the car even uses the same bulb sizeas mine
Old 04-05-2007, 01:39 PM
Fiirkan's Avatar
The higher the K rating the lower the actual light output. 4300 is pure white with the best output
Quick Reply: HID bulb question
