Help! Skirt + Lowered
#21
RE: Help! Skirt + Lowered
ORIGINAL: JerZy
mill$civic - how much did you pay for installing your springs? and what kind of srpings did you buy? where? since we live in the same city.
#22
I would go with 1"...but as long as u know how to drive a car that is low then u will have no problem..my car is low as crap...and i use to only scrape on driveways...but now i just park on the street...but u justt need to get a good angle at everything u go over...but u will be fine...
#24
Ok I got the measurement of clearance from my skirt to the ground = 4.5"
with everyones suggestion to lower is 1" so the clearance to be 3.5" === good enough for bumps maybe driveways?
#26
most speed bumps are probably about 3"... if you take them slow, and at the right angles, you shouldn't have any problems... and driveways, well that depends on the driveways in your area. 3.5" of clearance should be plenty if you drive the car right, like 1c1v1c1 and n8te said.
danomatic93
10-08-2007 04:35 PM
