Help! Anybody knows about this headlights?
#21
When you get them installed, post up some pics how they light up the road at night. I am interested in a cheap headlight upgrade. I also want to be able to have a set of OEM headlights ready to go in before I attempt to retro-fit just in case something goes wrong..haha.
#23
Right? They look blue, but if that how they look, I like them;however, I think they are not for "On Road use." I might get them now.
#25
[QUOTE=sfazngiants;648670]i just got the Nokya Cosmic in the mail today and installed them. Heres some shots i took
Hey man, could you take some pics of the light bulbs box? I just want to verify if the ones I am looking to purchase are the same. Thanks!
#26
They don't look blueish in real life, they look pure white.
You don't need pictures of the box, just buy them. It's a different bulb size anyway (you have an 8th gen, right?), so the box will be different anyway.
#27
guys dont buy these bulbs thinking they have a blue tint to the light. like trust said they are pure white. the first and second pictures looks more like the color of the light. I don't know how the last 3 pics came out with a blue glow, need to mess with my camera's settings.
#28
another option is re-wiring...but, I have no idea of how to do that.
#29
Hey man..I definitely want to buy those. Just one click away, but.... the OEM light bulbs in your car were 45/55 watts right?...I did some research and some people had problems installing 80/100 w light bulbs (melted, driving lights not working good). After having your lights on for a while, do the wires get very hot?
standard is 55 watts for an HB4/9006 bulb (the ones you use) (these use one bulb per beam unlike the H4 which is a dual filament bulb)
I don't have any problems with the Nokya bulbs, which run at 100/90 watts for an H4. My headlights aren't melting, the wires are fine, etc. Your wiring is better than ours too, because you have a new car with brand new wiring, and the wires are probably higher quality due to them being newer. If you get Nokya Cosmic White for your car (HB4/9006 Size), they run at 80 watts. You will have no problems at all.
Your high beams use a HB3/9005 bulb, which run at 100 watts for the Nokya Cosmic White, and probably 60 watts for a standard bulb.
So, if you want both the high and low beams to use those bulbs, you'll need a pair of the HB4/9006, and a pair of the HB3/9005.
#30
no problem with melting wires. The bulbs do get hotter than normal bulbs though, nothing that would cause any major problem. If your afraid of melting wires then i believe Nokya sells some wiring harness for higher wattage headlights
