Help on adjusting projector headlights please
I just installed a set of the Anzo projector headlights and the high beams are pointing up into the sky. Does anyone know how to adjust those downward. I tried to work with them when I bolted them in but they only have so much play in them.
RE: Help on adjusting projector headlights please
on the back of the headlight you will see a bolt or a screw, probably 2 of them, one to move the light up and down, and the other to move it side to side, you need to turn it left or right and depending what way you turn it, the headlight will move up or down or side to side..find the one that moves up and down and just keep adjusting it till you have the beam where you want it...you need to do this at night, the beam moves VERY slowly so you wont notice it when its light out
ya its actually the same with all headlights, in the back of my stock headlights its a little plastic thing that you turn tho, on my projecters its a bolt...theres only 2 in the back of the headlights, you cant miss it
I have ANZO Black Headlights too, but it has only 1 bolt. I'm still wondering if it's for the projector or for the high beam. I am having issues with my left projector lights. I noticed it beams on the same side of my right projector.
green1994civic
03-10-2012 08:03 AM
Snowwolfe
02-17-2006 01:39 AM
