Headlight wiring Question
Old 05-05-2007, 12:28 PM
98BlakCivic's Avatar
Default Headlight wiring Question
First Post
Thanks for your guys help in advance
Will be posting some pictures of Civic soo (98 Black 2 dr 5 spd)
My question is I bought some halos off ebay - they have a red and black wire coming from the headlight. Also has a 3 prong plug as well. im guessing i need a female wiring harness that did not come with the headlights? If i buy a female harness. How do i know what wire colors to connect to with the harness?
Old 05-05-2007, 12:40 PM
FlipHKD720's Avatar
Default RE: Headlight wiring Question
the harness plugs into the stock headlights harness, just unplug the stock headlights and plug in the new ones off ebay, easy as that.
And the red and black wires are for lighting up the halos, the black is the negative that needs to be grounded and the red is the positive that needs to be connected to a positive (12V) source, such as a switch or your running lights.
Old 05-05-2007, 12:43 PM
the plug is a 3 prong and i do not see similar connection from the stock wiring
Old 05-05-2007, 04:18 PM
Fiirkan's Avatar
ORIGINAL: 98BlakCivic
then you aren't looking, it is the same plug that your factory headlight bulb plugs into
Old 05-05-2007, 10:41 PM
cyberx32's Avatar
Take out your factory bulb, then pull it.......see that connection thats stopping you from taking it out? unplug that and plug in the new one. As for the two wires, you can splice into the parking lights and that way the halos will turn on whenever you turn on your parking lights.
Old 05-06-2007, 02:02 PM
OK just realized what you guys are talking about Got the new lights installed
Now the splicing part?
I Have Dual Halos so i have 4 wires on each light 2 blk 2 red
What wire is my parking lights and whats the best and saftest way to splice into them. a color and description would be cool thanks for your help so far dudes.
Paul D.
Fort Myers FL
98 Honda Civic EX Black 5sp 2 dr
Old 05-06-2007, 02:11 PM
danomatic93's Avatar
June 2010 ROTM
Red goes to parking lights wires
Black goes to ground.
I apologize for not having the color for your parking light wire. I have a 5th gen and will possibly have different color wires.
p.s. I may not be worth it to wire them up as they tend to burn out in as little as weeks-months.
Old 05-06-2007, 02:16 PM
does everyone think they will burn out in weeks or months and what can i do to combat that?
Old 05-06-2007, 04:48 PM
mill$civic's Avatar
Do This
Old 05-06-2007, 07:43 PM
cyberx32's Avatar
To wire it onto the parking lights, take off your bumper and follow the wire that your parking light is on, make sure you disconnect the battery and cut into that wire, i simply wired the black to the black wire and the red to the power wire from the parking light, now put them all toghether and make sure you tape them up real good. When i bought some halo lights off ebay about 2 years ago, they worked perfectly up until the day i sold the car (probably around 6 months) so it just really depends of the quality from the dealer.
Quick Reply: Headlight wiring Question
