Headlight question???
Okay, so I'm planning on buying these for my black 97 ex sedan....do I need to buy corner lights or is what is pictured everything I need? Sorry if this seems like a stupid question but I was gonna purchase some like these of ebay but the seller said I would need to buy corner lights as well...
Thanks for your help!!
http://www.k2motor.com/2lhcv96jmks.html
RE: Headlight question???
I like these to but I'm thinking the police will mess with me more with these...yes / no??
http://www.k2motor.com/lh-cv96jm.html
All of those have thecorner lights they are a one Piece unit. The black one's should be fine. I have amber bulbs for my corner light's white should be also fine. At least in California it is. Just don't use like blue,green etc on the corner light or you will then have problems with those cops.
WHO ever told you that on e-bay he is full of shi-t
I got some corner lights for you car if interested let me know... pm me
https://www.hondacivicforum.com/m_53.../tm.htm#534127
GP Thunder
One Pair 1157 LED Light(2 bulbs)
12V 24W
20 LEDs Per Bulb
Color: White
Wide View Angle/ Piranha Type
For Replacement of Your Turn Signal Light, Corner Light, , Parking Light, Side Marker Light, ETC..
Double the Light Output!
[align=left]Part#: 1157-20W[/align][hr]
This is for one pair of 1157 LED bulbs (2 bulbs) (Dual Beams)
Cross Reference: 1034. 2057
Total 20 LEDs Lights with Wide View Angle for better reflection. Double your current light output
Diameter 25mm (1.0"). 35mm height (LED part). 54mm total height.
Actually Color of our LED Light bulb. [align=center] [/align][align=center][/align]
GP Thunder
12V 24W
20 LEDs Per Bulb
Color: White
you won't need corner lights... what you'll probably need is amber corner light bulbs. I'm not sure on the 6th gens, but with 5th gens, the corner bulb is clear and the housing is amber. When I got my projectors, I needed to get amber corners because there was no amber housing in the new headlights.
ORIGINAL: reaper2022
Correct you won't need corner lights... what you'll probably need is amber corner light bulbs. Unless the housings it's already amberyou canput clear light bulbs
