Having Problems With My Hood Closing!
Hey guys, Ive read around on here about hood problems but none really seem to match the problem I am having. I put on a VIS CF hood a little over a year ago. I never had any problems with it, other than the nozzles for the windshield wiper fluid wont fit. Tonight I was trying to close my hood, but it wouldnt shut. The first latch goes over the hook, but the next one just wont pop up and latch it down. I lubed the ever living **** out of it and cleaned some gunk i saw in there, but still no go. Any suggestions? I am supposed to be leaving for CO tomorrow so I HAVE to get this fixed! Thanx!
RE: Having Problems With My Hood Closing!
most likely the cable is sticking and not allowing iit to close completely, i have a similar issue from time to time, if you look to the left of the latch a bit, you will the the cable with a ball on the end, and there will be a little metal part that looks like a can, take a screw drive and push on that and it should move about ½ an inch. then your hood should shut
