Glovebox LED's help
#44
i would tape them up back there with electrical tape to give the wires a little more insulation back there from being rubbed. whatever you do, don't bend them... there's a resistor on the back of each LED. Did you hot glue the LEDs in place?
#45
well i was talking about the switch.... leds you can bend just fine just bend slowly dont force it...
but for the switch if its touching the metal brace then tape it up really good so the power wires dont hit the brace and blow the fuse...
#46
yea they are hot glued in place. should i be worried, no exposed wire are touch the metal brace only the plastic insulator parts are. it should be fine as long as no exposed wire is touching the metal, am i correct?
#47
yep as long as no exposed wires can touch youll be fine.
of course you could always drop the glove box and put some black duct tape all across the UGLY RUSTY brace that will hide the brace alittle better and insulate it alittle bit more
#48
i think thats what i will do. thanks
Lambo Civic
09-24-2007 11:01 AM
jeremyp183
07-20-2007 11:46 PM
