Glovebox LED's help
Old 12-25-2008 | 10:05 AM
^ how does this work? does the lights turn on when the magnets are apart and off when its together? i ordered the switch already. i might get these magnets if that is what they should do. will they work?
  #22
Old 12-25-2008 | 10:29 AM
the magnetic switches are activated when the two terminals are seperated more than 3/4inch i believe.....
its simply a magnet and two spring loaded pieces of metal... with the magnet close to the unit then the metal are separated... at least thats what i believe.
the switch is definatly the easiest way to wire them up....
but a word of advice... also wire up one led to shine on the floor..... this way if the switch is not turned off and the glove box is closed youll be able to see the light on the floorboard as a reminder to turn the switch off and make it a different color than your blue ones already
there prewired leds are well worth it IMO when it comes to soldering and all that crap...
and to make it even easier... try a flood light led unit... i got 2 of these in white and they are VERY BRIGHT!!!! and the light output is really WIDE BEAM!!!
http://www.oznium.com/high-intensity-led-floodlight
tho i havent installed mine yet. i was going to put one under the hood and one in the trunk.
  #23
Old 12-25-2008 | 01:20 PM
i'm getting them in white. if i wire them to the cig lighter, wouldn't they turn off when i turn off my car?
  #24
Old 12-25-2008 | 01:21 PM
yea, they will
  #25
Old 12-25-2008 | 01:39 PM
o ok... ya the cig lighter will work good.
  #26
Old 12-27-2008 | 11:11 PM
i just got the LED's today and will install them tomorrow. but i have a quick question. it seems like the switch will need a 3/4" hole, but i dont want to spend $20 for a 3/4" drill bit, do you guys think i can use a dremel to dig that hole instead?
  #27
Old 12-28-2008 | 01:46 AM
croninc's Avatar
yea the dremel will work, just work it slowly and check often to make sure you dont make the hole too big. Do you know anyone with a lot of tools? you could always try to borrow them
  #28
Old 12-28-2008 | 02:47 AM
dito.... just keep test fiting so ya dont go to big
  #29
Old 12-28-2008 | 10:05 AM
Try tracing the base of the switch onto the spot you're mounting with a fine tip permanent marker. Then, cut your hole along the inside of that traced line. The dremel will work good. Repeatedly check your hole for fitment as addiction2bass said.
  #30
Old 12-28-2008 | 04:09 PM
i'm just done installing them right now, i will upload some pics when i get some night shots tonight. i think it turned out pretty good. looks a lot better than no light in the glove box. if anyone wants step by step instructions i will do one. it's just basically what trust and addiction told me. thanks guys
