dome light not working? I'm a noob!
Old 07-27-2006 | 08:32 AM
juvifan1's Avatar
Default dome light not working? I'm a noob!
Well I just bought a 96 Civic Sedan the other day, and it had alot of "things" done to it. This includes a very tacky "Blue" interior dome light.
Anyway, the light works, but why doesnt it come on when I open the door? It also does not beep or anything when I leave the lights on with the keys not in the ignition with the door open. Is this normal?
Any help would be greatly appreciated! The dome light switch is in the "middle" position.
Could a fuse be blown? Which one, and where is the fuse panel?
Sorry guys, I'm a noob with civics.
-Tim
Old 07-27-2006 | 11:05 AM
mill$civic's Avatar
Default RE: dome light not working? I'm a noob!
play around with the switch, try the different positions if you already didnt...it shouldnt make a deep noise if you leave it on, it only beeps when you live your dash lights on
Old 07-27-2006 | 11:31 PM
juvifan1's Avatar
ok well, the light turns on when the PASSANGER side door opens, but not the drivers side.
Any suggestions?
-Tim
Old 07-28-2006 | 07:55 AM
Froznface's Avatar
Check the button on the inside of your door area...it should be in the latch area on the body side. Make sure that it is intact.
Old 07-28-2006 | 02:53 PM
kg3's Avatar
kg3
do you have an aftermarket head unit? that could be a possibility
Old 07-28-2006 | 03:56 PM
accent0002's Avatar
id say check the connection for the little dinger thing...alot of people unplug this because its annoying
Old 07-28-2006 | 05:05 PM
ya where is the door dinger thing i want mine to work that way cause its anoying to have to pull the keys all the way out so it doesnt ding with the door open.....
but if it works with the passenger door then my guess would be your door pin switch is bad or could just be dirty.... look at where the pin switch is and pull back the interior trim panel to access the rear of the switch.. first make sure its conected. and if connected then with any kinda wire touch it to the pin switch wire and ground that wire.... if it dings then the switch is either broken or dirty and just not making conection.... alls it does is give it a ground.
i still wanna keep my alarms door triggers.... so just disconecting the wire from the switch isnt doable....
Old 07-28-2006 | 05:52 PM
juvifan1's Avatar
ORIGINAL: kg3
Yes there is a Kenwood CD player. Why does this affect it?
Old 07-28-2006 | 06:17 PM
from what ive heard on older civics the stock radio has thedoor chime unit build into it.... so if somone just pulled the radio and didnt keep the factory radio inplace that would be the problem...
Old 07-28-2006 | 06:30 PM
kg3's Avatar
kg3
the stock radio controls the dome light... theres a workaround ive seen before but i cant find it... need it for my self too
Quick Reply: dome light not working? I'm a noob!
